jh901
Jan 08, 2012Aspirant
Ultra 2 PLUS for Squeezebox streaming
Hi I'm looking to upgrade my Duo as it is not handling streaming very well. I understand that perhaps the RAM (or whatever the relevant specs are) is not up to the task. I need more hard drive sp...
mdgm-ntgr
Jan 09, 2012NETGEAR Employee Retired
1) Fine. The "Plus" has faster CPU, so if anything will run Squeezebox better.
2) What's a "Transporter"? Should be fast enough.
3) How big is your music directory? Could do that if you like but better to use a Frontview backup job to copy direct.
