jh901
Jan 08, 2012Aspirant
Ultra 2 PLUS for Squeezebox streaming
Hi I'm looking to upgrade my Duo as it is not handling streaming very well. I understand that perhaps the RAM (or whatever the relevant specs are) is not up to the task. I need more hard drive sp...
PapaBear1
Jan 10, 2012Apprentice
I am assuming you are talking about a blank HD into the Ultra +, not one with data on it. It's a simple process. Mount the drive in the tray, with the Ultra + on, open the door, insert the HD, latch the drive and close the door. The Ultra + (just as the other NAS units) will test the drive as to viability and size (cannot be smaller than the other drive) then initialize the drive and then start the resync. This will take some hours.
I have also ripped CD's onto my NAS, but then just play the .mp3 using Windows Media Player.
