jh901
Jan 08, 2012Aspirant
Ultra 2 PLUS for Squeezebox streaming
Hi I'm looking to upgrade my Duo as it is not handling streaming very well. I understand that perhaps the RAM (or whatever the relevant specs are) is not up to the task. I need more hard drive sp...
mdgm-ntgr
Jan 13, 2012NETGEAR Employee Retired
To see the "C" share you have to connect as the "admin" user. When you click the browse button in RAIDar it will open up the NAS in Windows Explorer by default attempting to use the credentials you logon to Windows or the saved credentials from previously connecting to the NAS (if you told your PC to remember them).
