shivasharana
Jan 16, 2017Aspirant
unable to access admin page after upgrading to 6.6.1 from 6.6.0
i am unable to connect to admin page. i can access share folders from network but not admin page. i can also ping and also access through ssh. It shows startup screen Netgear Ready nas 6...
schwuben
After upgrading FW from 6.6.0 to 6.6.1 this happened:
in the middle of a backup from 2 PC:s the backup terminated before finished with error.
After trying to access the NAS with Raidar (6) the message was "unit strting". That was the message the day after de FW update.
RN 104 could not be seen on network (could have been the cause of backup interuption)
After shutting down and restarting twice no access to Admin page (unit starting).
Access is possible via network, pinging and handling files is normal, but no access to Admin page.
Will it be possible to update the FW in the future?
mdgm-ntgr
Jan 16, 2017NETGEAR Employee Retired
Can you download the logs using RAIDar 6.2 and send those in (see the Sending Logs link in my sig)?
If you have SSH enabled you may wish to check how full the 4GB root volume is first.
- eieraugeJan 17, 2017Aspirant
I have the same Problem,Logs cannot Download. Raidar say "System is starting". Admin Page is not reachable. NAS 104 can reach at Network but not the Adminpage. OS 6.6.1 is installt on the NAS. Plex and Transmisson are install as Apps.
- mdgm-ntgrJan 17, 2017NETGEAR Employee Retired
shivasharana looks like you are using Active Directory. You should contact support and provide them your logs. I can see you have lifetime (online) chat support so you should use that.
