shivasharana
Jan 16, 2017Aspirant
unable to access admin page after upgrading to 6.6.1 from 6.6.0
i am unable to connect to admin page. i can access share folders from network but not admin page. i can also ping and also access through ssh. It shows startup screen Netgear Ready nas 6...
mdgm-ntgr
Jan 16, 2017NETGEAR Employee Retired
Can you download the logs using RAIDar 6.2 and send those in (see the Sending Logs link in my sig)?
If you have SSH enabled you may wish to check how full the 4GB root volume is first.
eierauge
Jan 17, 2017Aspirant
I have the same Problem,Logs cannot Download. Raidar say "System is starting". Admin Page is not reachable. NAS 104 can reach at Network but not the Adminpage. OS 6.6.1 is installt on the NAS. Plex and Transmisson are install as Apps.
- mdgm-ntgrJan 17, 2017NETGEAR Employee Retired
shivasharana looks like you are using Active Directory. You should contact support and provide them your logs. I can see you have lifetime (online) chat support so you should use that.
- SkywalkerJan 17, 2017NETGEAR Expert
eierauge, you seem to have misconfigured ReadyCLOUD settings. It looks like perhaps you set the proxy port to port 80, which conflicts with the HTTP service that is necessary to serve the admin page. You should still be able to access the admin page by using HTTPS explicitly. Once you remove the bad proxy setting and reboot, that issue should be resolved.
- eieraugeJan 18, 2017Aspirant
Hi Skywalker,
I dont have a Proxy configured. Also i can see and reconfigure that, if i can reach the Adminpage. But this is not possible at the moment.
Greetz
- SkywalkerJan 18, 2017NETGEAR Expert
You should still be able to access the admin page by using HTTPS explicitly. That is, type the URL in your web browser as https://nas-address.
