gyves1
Oct 25, 2025Luminary
Unable to activate the SMB
Hi, Since several days I had an unexpected disabling of my SMB on the ReadyNAS. I'm trying to reactivate the service but each time the App button go back to grey status. Do you have an idea of the...
Sandshark
Oct 25, 2025Sensei
If the OS partition is too full, the warnings are in the main log you can view from the UI.
gyves1
No warning about that
- SandsharkOct 26, 2025Sensei
So it doesn't look like that's what has caused the configuration file corruption (most likely smb.conf or one of the files listed on an INCLUDE line in it) . Do you have a saved configuration file before this started happening and before you added any new shares? If so, you can try uploading that. smb.conf is re-written every time you add or delete smb access for a share, so you can try just making a change there, too. Or you can wait for StephenB to take a look at your downloaded .zip and see if it points to a more specific problem.
- StephenBOct 26, 2025Guru - Experienced User
I've done that, and am not seeing anything obvious in the logs. FWIW, there are some similar errors with ClamAV that don't appear related to the virus definition problem. The log shows that the service(s) failed, but nothing else.
Though I'm not seeing any errors in the volume, I've suggested running the disk test next. Also the memory test.
- gyves1Oct 26, 2025Luminary
Hi Stephen and Sandshark
Thank you for your feedback
I will start the test tomorrow morning and I send here quickly a feedback
Have a nice sunday !!!
Best regards
Yves
