gyves1
Oct 25, 2025Luminary
Unable to activate the SMB
Hi, Since several days I had an unexpected disabling of my SMB on the ReadyNAS. I'm trying to reactivate the service but each time the App button go back to grey status. Do you have an idea of the...
Sandshark
Oct 25, 2025Sensei
If the OS partition is too full, the warnings are in the main log you can view from the UI.
Oct 25, 2025Guru - Experienced User
gyves1 wrote:downloaded the full log zip but hosnestly I don't know where to check...
If you like, you can send me a PM with a download link, and I will take a look.
Make sure the permissions are set so anyone with the link can download.
