gyves1
Oct 25, 2025Luminary
Unable to activate the SMB
Hi, Since several days I had an unexpected disabling of my SMB on the ReadyNAS. I'm trying to reactivate the service but each time the App button go back to grey status. Do you have an idea of the...
Nov 01, 2025Guru - Experienced User
gyves1 wrote:Currently I'm trying to make a backup before to do factorry reset of my ReadyNas but the device is completly unstable like a DDOS of the WebUI...so often busy to download the Web page , restarting the logging popup...
I'm searching a solution for this manual backup of my data before the reset
Do you have access to a linux system?
gyves1
Nov 05, 2025Luminary
Unfortunately no :-(
I forced the poweroff from the front panel.
I bought a new external SSD 2TB and an eSata/USB-C cable to make the ReadyNas Backup.
I restarted the ReadyNas, it seems more stable, I have access to WebUI now.
I connected the new external SSD (formated in GPT with a NTFS partition) on the eSata...nothing on the WebUI, same with the rear USB. Only the front USB can find/start the external SSD.
I think there a hardware problem with the rear USB and eSata.
So now, I started the full backup of the ReadyNas on my external SSD Samsung 9100 2TB, faster than my previous external disk.
I let you know when it's finished...after that I will try a factory reset of the ReadNas and check if the SMB service can be enabling or not after this master reset.
If not, I will open an RMA ticket to Netgear support because my RN422 still under official warranty for 1 month
