nomoss
Mar 24, 2023Aspirant
Unable to create shares - ReadyNas 2120, Firmware 6.10.8
My ReadyNas 2120 has been in use for several years and has been running fine. It has existing shares. Recently I tried to add an additional share and it failed. See the error message bel...
- Mar 25, 2023
nomoss wrote:
Question... in viewing the disk drives from the front of the chassis, are the drives oriented as /dev/sda => /dev/sdd going from left to right? If not, is there a way to identify which drive is which?
I'd guess left-to-right, but I don't have a rack-mount, so I am not sure.
disk_info.log gives you the serial numbers of the disks, so after the backup you could power down, pull the drives, and check for the serial numbers.
Once you have a full backup, it might be simpler to do a factory detault with the new drives in place. You can save the config files first, and re-apply them after the default to speed things up. There are a couple of settings that will miss (but unfortunately I don't recall which ones). If you have installed apps, make sure you re-install them before you restore the config.
nomoss
Mar 25, 2023Aspirant
/dev/sdc and /dev/sdd have non-zero uncorrectable sector counts as opposed to /dev/sda and /dev/sdb which have zero uncorrectable sector counts. The volume is a RAID-5 so errors on two disks can be an issue. Considering that this ReadyNAS has >56,000 continuous power on hours, it's not unreasonable to expect drive issues.
I have a second ReadyNAS 2120 with sufficient free storage capacity and am currently running full rsynch backups of the flakey 2120 to it. Upon completion and verification of the backups I will replace the /dev/sdc and /dev/sdd drives, reinitialize the first 2120 and restore the data.
Mar 25, 2023Guru - Experienced User
- SandsharkMar 26, 2023Sensei
After a boot, they are usually aligned that way. But if you replace one and have yet to re-boot, they won't. But in some cases, they aren't ever aligned that way. On my RD5200 converted to ReadyNAS OS, sda is drive 4 (of 12). But it has a SAS expander backplane, not a simple SATA one, and that may just be the first drive the OS sees on boot.
If you hover on the drive on the Volumes tab, it will tell you which is which.
