N_i_c_k
Jan 26, 2020Aspirant
Unlocking encrypted RAID with USB disk
Hello, Apologies if this has been answered before. I couldn't find it here, nor it is mentioned in the manual: - What filesystem does the USB drive need to be? MS-DOS FAT / FAT32 surely doesn't...
N_i_c_k
Thanks Stephen.
I used to unlock it with an external HDD attached to the NAS permanently, but that's gone now.
That being said, I'm absolutely sure it was not NTFS or btrfs.
That leaves ext2/3 on the table I guess?
Jan 26, 2020Guru - Experienced User
Yes. Though I'd have thought that fat32 would work for this.
- N_i_c_kJan 26, 2020Aspirant
Im guessing the name is still data.key?
No luck with ext3 either.
NetGear are very close to getting called and thanked for losing 10+ years of personal photos.
Discussion with attorneys on Monday.
Trying with an external HDD formatted with ext4.
The system is reading the disk.
And I can see the data.key there when logged to the NAS with SSH.
But it still says "Failed to activate encrypted volume data...."
- SandsharkJan 26, 2020Sensei
I'm not completely sure what you are trying to do. Are you trying to re-create a USB "key" for unlocking your NAS volume because the old one is lost or non-fuctional? Those are normally FAT32. I wouldn't expect the format to matter as long as the key file is correct, but I don't use encryption. The key file does need to be in the root directory.
Assuming you do get this worked out, you really need a backup plan. Those 10 years of photos are certainly not completely protected on your NAS. There is an old IT saying: "If you only have one copy of something, you must not think it's important." For photos, cloud backup is often a good choice since retrieval speed is not normally critical.
