adb1
Mar 07, 2013Aspirant
Unresponsive ultra 2 plus
This morning my U2P was not 'visible'. ping does not work - destination host unreachable. Power button would not shut down the box and no access to Frontview. I rebooted with 5 second power off t...
adb1
Mar 11, 2013Aspirant
I've taken the disks out and stuck them in a Windows 7 box and they are recognised by Windows, but Seatools does not see them! Anyway, I've been searching these forums on how to access the data on the drives.
I've tried rstudio, which in 4 hours will hopefully let me see the data, well I'll be asleep then, however, the Linux Disk reader mentioned in the thread
viewtopic.php?f=11&t=35153
did not work.
Does the DUO mentioned in that thread use the same file system as the U2Plus?
did not work.
