adb1
Mar 07, 2013Aspirant
Unresponsive ultra 2 plus
This morning my U2P was not 'visible'. ping does not work - destination host unreachable. Power button would not shut down the box and no access to Frontview. I rebooted with 5 second power off t...
mdgm-ntgr
Mar 11, 2013NETGEAR Employee Retired
The Ultra 2 Plus uses a different RAID format and the volume uses the EXT4 filesystem with the standard 4k block size. So the procedure to mount the array using Linux would be different (it is a bit easier to mount an array from a U2P than it is from a Duo).
