adb1
Mar 07, 2013Aspirant
Unresponsive ultra 2 plus
This morning my U2P was not 'visible'. ping does not work - destination host unreachable. Power button would not shut down the box and no access to Frontview. I rebooted with 5 second power off t...
Mar 11, 2013Guru - Experienced User
The OS is on the disks. So there is no value in factory resetting the box, and then reinstalling the original disks. Also, that means (2) does not impact your original settings, as they are on your original disks.
Personally I'd back up the data before playing with your original drives. Theoretically you can do (1), but if you (or any process on the NAS) writes to the data drive then you lose the integrity of your RAID array.
