adb1
Mar 07, 2013Aspirant
Unresponsive ultra 2 plus
This morning my U2P was not 'visible'. ping does not work - destination host unreachable. Power button would not shut down the box and no access to Frontview. I rebooted with 5 second power off t...
adb1
Mar 12, 2013Aspirant
I tried both 1 and 2 disks in the drive, no luck, finally Netgear told me to ring support. Did a factory reset with a new drive and same problem, so they're RMAing the chassis and I get a replacement tomorrow - for the sum of A$40.
I'm in the process of pulling the data off the drive in an Ubuntu VM, but it's very slow. I'll put a couple of the WD RED WD30EFRX drives in instead and see about RMAing the Seagate drives anyway.
