spinaltap1
Aug 08, 2012Aspirant
Upgrade Disk Firmware via ReadyNAS?
Forgive my ignorance, but if I purchased a couple of Seagate Barracuda 7200.14 ST2000DM001 drives for my NV+.v2, am I able to upgrade the CC4H firmware by simply connecting my ReadyNAS to a Windows-ba...
Aug 08, 2012Guru - Experienced User
No, that won't work at all. You need to connect the drives to the PC, not the NAS. There are USB/IDE/SATA converters you can buy for this purpose (though if you have a desktop you can simply connect the drives to the PC internally using a spare SATA and power connector).
spinaltap wrote: ...am I able to upgrade the CC4H firmware by simply connecting my ReadyNAS to a Windows-based laptop connected via USB?
