spinaltap1
Aug 08, 2012Aspirant
Upgrade Disk Firmware via ReadyNAS?
Forgive my ignorance, but if I purchased a couple of Seagate Barracuda 7200.14 ST2000DM001 drives for my NV+.v2, am I able to upgrade the CC4H firmware by simply connecting my ReadyNAS to a Windows-ba...
Aug 09, 2012Guru - Experienced User
I think you're asking a question without a definitive answer. Seagate's response is quoted here: http://www.legitreviews.com/news/13250/
spinaltap wrote:
StephenB wrote: Most of the recent posts are on the ST2000DL003-9VT166, not the ST2000DM001.
So...?
I don't see much here that goes beyond that.
The new firmware download, version CC4H, is recommended to enhance the performance and/or reliability of the drive. Previous versions of firmware with these models and part numbers are CC46, CC47, CC49, CC4C, or CC4G. The upgrade is a free download available here and we are told that this helps with the chirping noises that some users are complaining about.
Since the new firmware patch was made available 2 months ago, it is also reasonably likely that a newly purchased drive would have it (that depends on the retailer's inventory of course).
Probably a better strategy is to ask a pre-sales question on the Seagate site, saying that you need CC4H firmware, and that you can't upgrade the firmware because you don't have a suitable PC. They might be be able to give you a path to ensure you get an up-to-date drive.
Or buy from a retailer who has a good return policy, and return the drive if it is downrev.
