spinaltap1
Aug 08, 2012Aspirant
Upgrade Disk Firmware via ReadyNAS?
Forgive my ignorance, but if I purchased a couple of Seagate Barracuda 7200.14 ST2000DM001 drives for my NV+.v2, am I able to upgrade the CC4H firmware by simply connecting my ReadyNAS to a Windows-ba...
bigpallooka
Aug 10, 2012Aspirant
StephenB wrote: Are you just putting the drives in the HP to update the firmware? Or are you wanting to host the files from the HP instead of a Readynas?
Just to update the firmware to see if it will fix the HDD squeak. If not I will send the guilty drive back. I was mainly just concerned about whether SeaTools would find the disks. I may put the drives in the N40L but I haven't deleted the original source of the NAS data yet so it's not an issue.
Thanks for the advice.
