pw_ng's avatar
pw_ng
Upgrade from NV+ to 424 (kind of URGENT!)
Help!
I have an old NV+ which has died.  I guess power supply problem, because the unit is lifeless.
It was time for an upgrade anyway, so I bought a 424, for use with the same set of 4 x 2TB WD HDDs. These disks contain a large collection of critical data, in a RAID array, selected precisely because I expected that this woud be my reliable long-term storage for personal data.
I found a youtube video which said I could simply move the disks to the new enclosure, they would be recognised and I'd be upgraded. Which made sense.
But, the new 424 reports that I have Dirty Disks and only offers the option to reformat.
I have reversed the order of the disks, thinking I might have got that wrong, with no better result.
What can I do to access/recover these disks?
I really hope for authoritative advice from Netgear here, because I'm a long term customer and have put my faith in their products for this rather critical storage application.
Thanks.
Paul.
  • Here's what RAIDar says.
  • StephenB's avatar
    Perhaps it makes sense, but it isn't true.  You can't directly migrate from the legacy NAS (4.1.x, 4.2.x, 5.3.x firmware) to OS 6 ReadyNAS.
    In the case of the NV+, the disks can be mounted temporarily in the RN424 by support.  Then you have to backup the data to other storage.  You then set up the system to run OS-6, and restore the data from the backup.
    I believe support charges for this.
    https://kb.netgear.com/29876/ReadyNAS-Migrating-disks-from-RAIDiator-4-1-or-RAIDiator-5-3-to-ReadyNAS-OS-6
    • pw_ng's avatar
      pw_ng
      Thank you very much.
      Thing is, my ReadyNAS NV+ chassis is dead.  Do I need a working NV+ chassis in order to recover the data from the disks?
      The website here is not very clear at all, so I hope NETGEAR support can tell me what I need to do.
      • StephenB's avatar
        If you use the process in the KB article I posted above then you don't need a working NV+ chassis.
        What do you find unclear in the KB link?
        Personally I find some lack of clarity around the costs, but the process looks clear to me.
ProSupport for Business
