faizalktk
Feb 08, 2016Aspirant
Upgrade HDD on RN3100
Hello, We are using RN3100 in our environement and we would like to upgrade HDD storage on the same. Details of our device are as below: Model : ReadyNAS 310...
faizalktk
Hi Mdgm,
Thanks for your reply.
Our RN 3100 came with 8TB raw disk space and we never did any changes on the configuration.
Our plan is take full data backup before performing any changes.
So how i can bring this device working with 16TB raw data (4 x 4TB HDDs) instead of 8TB raw data (4 x 2TB)
I am bit confused about the 8TB expansion limit over the life of the volume in your reply. Could you please explain the same.
Also i would like to know how i can upgrade the firmware
BR,
Muhammed QTR
Doha-QATAR
Feb 08, 2016Guru - Experienced User
There is a check-for-updates button in the admin web ui. click on "system" on the left menu, then "update".
If you did the initial install of the system with 2 x 2TB disks inserted, your starting volume size would have been 2 TB. The maximum volume size would have been 10 TB. Since that is less than 12 TB, your system would stop expanding when you inserted the 3rd drive (so the fourth expansion attempt would fail). A factory reset would be needed to fix this.
- mdgm-ntgrFeb 08, 2016NETGEAR Employee Retired
For the RN3100 you should look at enterpise level disks. Perhaps a WD RED Pro 4TB WD4001FFSX or a SeaGate NAS Enterprise ST4000VN0001.
Note there are implications for choosing a disk outside the compatibility list, but if you do choose one outside it it is important to make a sensible choice. For rackmount that means going with an enterprise disk.- StephenBFeb 08, 2016Guru - Experienced User
I think the seagate enterprise model would actually be the ST4000NM0124, and not the VN. The VN is positioned against the WD Reds, not the RED Pros.- mdgm-ntgrFeb 08, 2016NETGEAR Employee Retired
Looking at SeaGate's website the SeaGate NAS and the SeaGate NAS Enterprise disks have very similar model numbers.
Enterprise disks not specifically targeted at NAS are another thing again and should also be considered for rackmount models.
