faizalktk
Feb 08, 2016Aspirant
Upgrade HDD on RN3100
Hello, We are using RN3100 in our environement and we would like to upgrade HDD storage on the same. Details of our device are as below: Model : ReadyNAS 310...
faizalktk
Feb 10, 2016Aspirant
Hi All,
Thank you very much for your valuable answers.
Hi Mgdm,
We have started with 2TB x4 =8TB as the initial storage. so shall i upgrade to 16 TB (4TB x 4).
Thank you.
If it is directly not possible let me know, how i can make reset to factory and use 16TB.
Thanking you in advance.
~Muhammed QTR
mdgm-ntgr
Feb 10, 2016NETGEAR Employee Retired
That expansion should work fine.
Regardless of which way you want to go it would be advisable to make sure your backup is up to date as your next step.
