brandtz's avatar
brandtz
Upgrade to 3 Gb disk ?!
Have a reday NAS DUO with 2 GB disk. Now need to upgrade to two 3 GB disks to get more space AND mirroring.
Added "ForceExpansion" that said OK.
Inserted one 3 GB disk and it says, faulty disk, cant be used. So I opened the other disk package and installed IT......same message.....no I think it is the Ready Nas that is faulty....
Any suggestions?
  • Sounds like you have a v1 Duo that does not, and probably will not, support disks greater than 2TB.
    What version of RAIDiator are you running in your Duo?
  • Model: ReadyNAS Duo [X-RAID], Serial: 24M3027R02D00, Firmware: RAIDiator 4.1.6 [1.00a043]
    I think it is a V2 actually?!?! How can I tell?
  • The RAIDiator version 4.1.6 means that it is a v1. Some of them have a v2 on the back but that is a v2 of the v1 ( if that makes sense). Probably just a minor hardware revision but still Sparc based.
    The true ARM based v2 use RAIDiator 5.x and up.
  • It says "RND2000 v2" under it looked it up and found the Netgear page: http://www.netgear.com/home/products/storage/prosumer/RND2000.aspx#two
    But how can "maximum internal capacity" be 6Tb as it says there?
  • As I said, the v2 on the back of yours refers to a minor hardware change. They probably couldn't get a component from a vendor anymore so they had to slightly change some internal hardware, thus the v2 of a v1 Duo.
    The link you provided is for a true ARM based Duo (a v2 Duo). Yours is a Sparc based Duo v1 even though it says v2. Naming nightmare!
  • StephenB's avatar
    Netgear regrettably created a lot of confusion when they branded the ARM units as "v2" - since as you discovered, they had used "v2" already for the original Duo model number.
    Since you are running 4.1.6 firmware, you absolutely have a sparc-based unit, which is called "v1" throughout the readynas forums and main readynas page.
    So it does not support 3 TB drives.
ProSupport for Business
