Clarkson
Dec 16, 2013Aspirant
Upgrade to duo v2
Hi Because I want to use certain apps I want to upgrade my duo to a v2 from my v1 . If I buy a new one can I just put my drives In from the old one. Will it read data ok etc. Cheers John
mdgm-ntgr
Dec 16, 2013NETGEAR Employee Retired
No. The RAID format is different.
Anyway the Duo v2 is discontinued as well. You may as well buy a RN102 and transfer your data across your network to the new NAS then use your Duo v1 as a backup NAS.
