Clarkson
Dec 16, 2013Aspirant
Upgrade to duo v2
Hi Because I want to use certain apps I want to upgrade my duo to a v2 from my v1 . If I buy a new one can I just put my drives In from the old one. Will it read data ok etc. Cheers John
mdgm-ntgr
Dec 21, 2013NETGEAR Employee Retired
Yes. If you do a factory default the v2 should format the disks.
