KaySee's avatar
KaySee
Upgrading from RN212 to RN214
Upgrading from my RN212 to a RN214 and want to migrate my two 6tb drives and add two more eventually.  The two 6tb drives are set up X-Raid.  Can I just take the two 6tb drive out of the RN212 and put them into two of the slots in the RN214 and then boot up the system?  I can add the other two drives latter.  I know there are similar posts, I just wanted to be specific. Thanks
  • Hi KaySee
    Welcome to the Community!
    You can definitely do that procedure migrating both disks on another OS 6 Unit. You can check here Migrating a Volume
    Since the two 6TB are on X-RAID once you have added new disks it will expand and change it's RAID type automatically.
    Hope this helps!
    Regards
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    Hi KaySee
    Hope this helps!
    Regards
      • Marc_V's avatar
        Marc_V
        Hi KaySee
        We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
        If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
        The Netgear community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
