mlswayze's avatar
mlswayze
UPS - Battery Backup / Installed New Batteries / How to clear "warning" message on Admin Page
I had some batteries start to fail on my UPS Battery Backup.
I replaced the batteries inside UPS.
How do I reset / clear the UPS warning message inside The Admin Panel (Radair)?
  • StephenB's avatar
    It should have cleared itself.  Did you try removing it, and adding it again.
    • mlswayze's avatar
      mlswayze
      Yes I removed the device, unplugged the UPS and re-installed.
      The message is still there
      • StephenB's avatar
        Have you tested the UPS?
        Maybe connect it to a PC and install vendor tools (PowerChute, etc).
ProSupport for Business
