rcolman
Jun 24, 2015Aspirant
UPS Recommendation for ReadyNAS 204
Please recommend a model for my newly acquired 204.
TNX.
Rick
TNX.
Rick
- mdgm-ntgrNETGEAR Employee RetiredA SMART-UPS with a USB port
- rcolmanAspirantHow big if I only care about powering the NAS with 4-drives (2 right now)??
- mdgm-ntgrNETGEAR Employee RetiredDon't need that much runtime to shut the NAS down safely. Allowing a minute or two for the NAS to shutdown would be plenty. Also, you don't want to put more than 80% load on the UPS or else the battery will drain too quickly.
So it depends on how much runtime you want which model you get. - rcolmanAspirant2 minutes is fine.
- rcolmanAspirantbe nice to have a number ...
- vandermerweMasterAPC has a product selector tool on their website.
The entry level units are fine but have a year less warranty.
Smart UPS are not cheap compared to the Back-UPS range. These cheaper ones with USB monitoring have RJ50 to USB proprietary cables which can be problematic and are expensive to replace. The smart ups units will accept a standard device to USB cable.
There are other manufacturers of UPS devices.
I doubt you'll get a specific device number from anyone, it depends on where you live, prices locally, your current and future load, warranty requirements.
I also believe it helps do do your own research, you have a better understanding of what you are buying. - StephenBGuru - Experienced UserPersonally I use a CyberPower CP1500AVRLCD with my RN202.
It is shared with a nearby desktop PC, but the USB connector is attached to the RN202.
I have two other CyberPower in the basement with the main network stuff - they protect several NAS (including an RN100), my main switch and router.
- Apr 03, 2016Retired_Member
