fesh
Jan 29, 2012Aspirant
USB 3.0 ports on NV+V2
What are the two USB3.0 ports usable for? Can I plug in an external USB3.0 harddisk, and then share this volume like it was an internal disk of the NAS? If not, why not? Of course, it couldn't be ...
PapaBear1
Jan 29, 2012Apprentice
You misunderstood what I said. The external drives WOULD NOT be added to the RAID volume. You said share - and they would be shared across the network, but as stand alone volumes, not part of the RAID volume. When I connected a USB drive to my NV+ as a test, I could access the USB drive (after entering a password which is not needed for the RAID volume) and see the files. That is what I meant by sharing. I do not consider the RAID volume as sharing drives, for they are configured as one large volume with multiple shares. Share in this context is the same a a first level directory/folder off the root.The external drive is shared as a drive by itself.
If you intend to share this external drive to multiple users, permissions could be a problem. I do not have users set up on my NAS unit, and had to enter the ADMIN sign on and password to gain network access. I don't know if you would want to do this in the case of multiple users.
