dsm1212's avatar
dsm1212
Apprentice
Dec 10, 2011
USB Hub recommendation for the pro?
Anyone got an inexpensive one that they know works? So many of these it's hard to choose. I'm looking for just 4 port powered.
thanks
steve
  • Well, to answer my own question:
    I purchased this one because it indicated it worked with linux:
    http://www.monoprice.com/products/produ ... 1&format=2
    In fact it does work very well with 1 quirk. I have a WD Live and two Seagates GoFlex drives. The Seagates didn't spin up automatically and appear on frontview when connected through the Hub. The seagates are usb 3.0 drives and have a USB 3.0 cable which is supposed to be compatible with 2.0, but after perusing the internet and reading other peoples comments I found the suggestion to use a USB 2.0 cable and that fixed it. With the 2.0 cable the drive comes right up every time it's attached.
    thanks,
    steve
  • Basically any hub should work. I got mine for 2€ afair. Quit simple and small with 4 ports and working great.
ProSupport for Business
