aalexandrebeta's avatar
Feb 27, 2017
USB recomandations
This should be interresting to have clearer recommandations on the HDD, type of partition and so on just to save users time and NG's!
  • FramerV's avatar
    FramerV
    NETGEAR Employee Retired
    Hi aalexandrebeta,
    Unfortunately there is no official release of compatible USB drives for the the ReadyNAS. Such a list would be difficult to administer, and keep updated.
    This was stated on ReadyNAS OS 6: USB Port use.
    • Brwosing topics on this community makes me think that there is a lack of precise and clear recommendations on that matter.
      Often WD and SG casing use a proprietary program and their own way to configure witch disturb NG a bit. On the contrary generic equipment do not have those issues. When people have 2, 3 partitions on their drives it messes it a bit!
      I am a bit a pain in the botom but having to deal with parents and relatives a bit grumpy they need a procedure!
      So clear steps and precise instruction would avoid some mess!!
      Regards!
      • FramerV's avatar
        FramerV
        Hi aalexandrebeta,
        You have some good points there, if you have not done so; it might be best if you can also post this on our Idea Exchange for ReadyNAS.
ProSupport for Business
