KillerBob's avatar
KillerBob
USB2 drive in USB3 on the Ultra 2
Hi,
I have just setup my new backup NAS, an Ultra 2. As I have my backups on two external housing units from Taurus with all my data (my Pro Pioneer is currently awaiting Netgear interaction), I connected one of the Taurus units to the front USB3 port on the Ultra, but the Ultra doesn't even see it. I connect it via one of the USB2 ports on the back, and it is fine.
And don't worry, I am NOT believing that I will get USB3 speeds from my Taurus units, but it is easier to use the front USB port:)
Bo
  • Hi Mdgm,
    The Bios version log shows:
    09/08/2010 ReadyNAS-ProUltra2 V1.4
  • I purchased this unit a month ago brand new. Funny it came with an out of date BIOS.
    Will try the add-on later and report the results.
  • Ok, updated the BIOS, it now reports V1.8. It appears to solve the problem partly. My Freecom drive will mount now with USB3 and I can access it as a share over the network IF it mounts. Mounting does work sometimes and sometimes still not, but mostly not. Beast chance is when I first connect the drive powered off and connect the USB3 cable first. Then I have to power on the USB drive to get it working occasionally. Connecting an already powered on USB drive doesn't mount for sure.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Update to 4.2.22 and if you still have issues open a support case and post your case number.
  • Hi Mdgm,
    The enhancements/bug fixes list of V4.2.22 shows nothing related to this problem, updating looks like a shot in the blind. But I will try. Looked at the system log file and that showed several software related errors. I have not much time for it at the moment, I will look further into it next weekend. Thanks anyway for the support so far.
ProSupport for Business
