barryd
Feb 02, 2016Aspirant
Using UPS with ReadyNas 102
Hello I need to install a UPS on a ReadyNas 102. The power supply to the office is not that great and whilst the NAS is currently on a surge protected supply there is no UPS in place. Would ...
Feb 02, 2016Guru - Experienced User
barryd wrote:
Hello
Protecting your NAS with a UPS is a very good idea, and I always recommend it. A lot of problems here start with an unexpected power loss.
barryd wrote:
Would this device from APC be suitable please? http://www.apc.com/shop/gb/en/products/APC-Back-UPS-700VA-230V-AVR-IEC-Sockets/P-BX700UI?_requestid=9103
It looks suitable to me. APC is a popular choice here, and there aren't many issues reported. I happen to use CyberPower myself, but that is mostly habit - not because of any issues with APC.
barryd wrote:
...the NAS will gracefully shut down anyway if it detects low power on the battery of the UPS. Is that the case with the ReadyNas 102?
Yes. You just need to connect the UPS to the NAS over the USB port. No need to install any special software on the NAS.
barryd wrote:
I just need to understand how the 102 will be shut down safely in the event of a power cut and is there a away it can be automatically restarted once power is resumed?
The NAS shuts down when the UPS sends a critical power alert to the NAS. Once that happens, you need to manually restart the NAS. You can probably do that remotely if you have WoL enabled.
Since it won't automatically restart, you should try a get a UPS with a good enough battery to carry you through most power failures. If this is a major issue for you, then maybe get a UPS with a higher VA. Though the RN102 is quite good on power use - smallnetbuilder.com measured 16 watts with 2 WD30EFRX drives installed (and spinning).
barryd
Many thanks for that really useful reply. I have however now been advised from my supplier that the APC unit I linked to does not come with the powerchute software which I think might be incorrect as in the link it states "Use your PC to access additional power protection and management features for your UPS via a USB Port." Which kind if suggests it can be controlled via the USB port. Its so confusing. I Cannot seem to get sensible answers from either our suppliers or APC.
I have however had it confirmed that this device from Tripp Lite does come with USB support and free software for auto shut down. I know now that its not necessary or even possible to load the software on the NAS but it clearly does have to have a USB connection to the NAS or will it just detect low voltage? I would like to get the same models for the desktops as well and they will need shut down software. Sorry about this but do you think the one below will be suitable? I think its slightly more powerful.
- mdgm-ntgrFeb 02, 2016NETGEAR Employee Retired
The NAS uses NUT (Network UPS Tools). Most APC UPS units work well with that.
- StephenBFeb 02, 2016Guru - Experienced User
barryd wrote:
... do you think the one below will be suitable? I think its slightly more powerful.
Actually the APC has more power (700 va compared to 550). APC estimates about about a 2 hour run time with a 16 watt draw.
As mdgm says, the NAS has the NUTS (Network UPS Tools) software built in. The Network UPS Tools folks have a list of APC models that support their tools here: http://www.networkupstools.org/ddl/APC/ - and a tripplite list here: http://www.networkupstools.org/ddl/Tripp_Lite/index.html
There could be other models that work too, you can search this forum for them (with google, just add site:community.netgear.com to the search string).
Note we don't support using UPS units that use a serial to USB cable.
