LesZ
Aug 01, 2017Aspirant
Volume lost after failed drive replacement trying to recover data
Firmware 6.7.5. MY unit is set up in X-Raid. All 6 drives are 4TB Wester Digital WD4000FYYZ including hte new replacement drive.
I have two issues.
1. Drive #6 failed. I have replace it and formated it but it did not rebuild automatically. How do I force this.
2. Drive #3 is installed but does not show up. It appears on the volume page as just a blank area, no drive indicated. Ideas?
LesZ wrote:Drive #6 failed. I have replace it and formated it but it did not rebuild automatically. How do I force this.
Normally you should insert it unformatted. Did you format it via the web admin ui or somewhere else?
If somewhere else, try clicking on the drive and then clicking format.
Do you know if it is in the array? You might download the log zip from the web ui
- check disk_info and see if it shows up.
- check mdstat and see if all drives appear there. Also see if you have any unused devices.
Do you recall what volume size you had before the failure?
- LesZAspirant
I first installed the drive unformated and it did not rebuild. I then formated from the admin UI still no joy.
I have downloaded the logs and under disk_info I see channel 0, 1, 3, 4, 5. Could this be a dead slot?
It could be. It could also be a dead disk, so you might try powering down the NAS and seeing if the disk shows up in a PC. (It won't mount, but in Windows, the Windows Disk Manager will see it. So will diagnostics like Seagate's seatools and WDC's lifeguard).
Is the NAS still under warranty? That should be 5 years for the original purchaser. Also if you purchased between 1 June 2014 and 31 May 2016 you have free lifetime chat support at my.netgear.com.
