Nate_Cochrane
Dec 29, 2013Aspirant
WD 3TB recommendations for Pro Pioneer?
Hi I have a Pro Pioneer stacked with five WD RE4 drives (WD2003FYYS-01T8B0 and WD2003FYYS-02W0B0) and would like to start incrementing to 3TB WDC drives or greater starting from the sixth drive. ...
mdgm-ntgr
Dec 29, 2013NETGEAR Employee Retired
So you had all five in place? You didn't add them one by one with a resync in-between. What RAID mode are you using?
