Nate_Cochrane
Dec 29, 2013Aspirant
WD 3TB recommendations for Pro Pioneer?
Hi I have a Pro Pioneer stacked with five WD RE4 drives (WD2003FYYS-01T8B0 and WD2003FYYS-02W0B0) and would like to start incrementing to 3TB WDC drives or greater starting from the sixth drive. ...
Jan 02, 2014Guru - Experienced User
I've been using several WD30EfRX for about a year with good results. Though apparently a recent production change has resulted in the load cycle count issue recurring again on new drives You can run wdidle3 to reset the head parking timeout, though WDC doesn't want you to...
I have no experience with either the WD3000FYYZ or the WD4000FYYZ
