bartw
Mar 29, 2016Aspirant
WD RED PRO 6TB WD6001FFWX vs WD6002FFWX
Hi all, anyone any experience with the WD6002FFWX (as oppososed to WD6001FFWX which is on the compatibility list)? We can no longer order the WD6001FFWX and I want to know if the WD6002FFWX i...
error404
hi,
I have 1 x WD6001FFWX and 2 x WD6002FFWX all working smoothly together
JennC
Mar 30, 2016NETGEAR Employee Retired
Hello bartw,
Error404 shared his experience. Thanks to to him.
We usually use the HCL but some users still use ones that are not listed. It's basically it may or may not work thing. Moreover, we always strongly recommend to have full backup of the data.
- error404Mar 30, 2016Aspirant
Hi JennC
I do believe the WD6002FFWX should be added to the recommended list of drives as this is a direct replacement for the WD6001FFWX.
As bartw stated you cannot buy the WD6001FFWX anymore- JennCMar 30, 2016NETGEAR Employee Retired
Hello error404,
There is a plan of releasing HNCL instead of HCL which I believe is much better. Hopefully, this will push through.
