roy9183
Mar 07, 2010Star
WD WD1002FAEX
Please advise if the below WD1002FAEX model from WD is compatible with the NAS Storages????
Roy
Roy
- skrutten84Aspirant
PapaBear wrote: No. If the 1TB version is not on the list but the 2TB is, the 1TB is still unsupported.
Thank you for your help. I will go back and see what they can offer instead. - biche2AspirantHello,
I finaly succed in managing my WD1002FAEX-00Z03A0
Raidar: 4.1.9
The disk coundn't be reckognize alone, i had only message "disk missing" "bad disk" or "corruped root"
I fond a solution that work:
1) Shut down the nas duo
2) cut the power on the back
3) Put a disk that nas duo can handle normaly and put it in slot 2
4) Put the WD black 1TO in slot 01
5) Make factory reset (put a needle in the back , put the power and extract the needle only after seeing the "2 flash" in front)
6) Lanch raidar (soft) afer some second the 2 disk are reconized, and you can access to the manage option, click it
7) Chose between X raid au flex (i choose) flex (raid 0)
8) Extrat the second disk
9) THEN lanch "initialisation"
10) When finish you could use a second WD1002FAEX-00Z03A0 (don't know only have one)
Seems to work properly, but not enough time used for the moment
Any way, has the manipulation is a bit triky, I will use known working well, after 1 week of test with the WD1002FAEX-00Z03A0.
