atz6975
Sep 20, 2008Guide
WD10EACS: Huge Load cycle count [ NOT SOLVED] in 4.2.9
Hi, could ze jedis give their opinion on the following situation: While checking my smart values after a forth drive expansion (4x1TB) I found that my three other drives that are 7 months old have...
atz6975
Sep 20, 2008Guide
Obviously there are two wd10eacs references...WDC WD10EACS-00ZJB0 (old) and WDC WD10EACS-00D6B0 (new)
Disk 1,2,3 of 4 show same kind of numbers and increase rate. They are 7 months older than Disk 4. And disk4 doesn't increase its count at all as opposed to disk1.2.3.
SMART Information for Disk 1
Model: WDC WD10EACS-00ZJB0
Firmware: 01.01B01
SMART Attribute
Raw Read Error Rate 0
Spin Up Time 7725
Start Stop Count 834
Reallocated Sector Count 0
Seek Error Rate 0
Power On Hours 4996
Spin Retry Count 0
Calibration Retry Count 0
Power Cycle Count 9
Power-Off Retract Count 7
Load Cycle Count 218907
Temperature Celsius 33
Reallocated Event Count 0
Current Pending Sector 0
Offline Uncorrectable 0
UDMA CRC Error Count 0
Multi Zone Error Rate 0
ATA Error Count 0
Extended Attribute
Hot-add events 0
Hot-remove events 0
Lp stat events 0
Power glitches 0
Hard disk resets 0
Retries 0
Repaired sectors 0
SMART Information for Disk 2
Firmware: 01.01B01
SMART Attribute
Spin Up Time 5408
Start Stop Count 945
Seek Error Rate 0
Power On Hours 3804
Spin Retry Count 0
Power Cycle Count 9
Load Cycle Count 245819
Temperature Celsius 37
ATA Error Count 0
Extended Attribute
Hot-add events 0
Hot-remove events 0
Lp stat events 0
Power glitches 0
Hard disk resets 0
Retries 0
Repaired sectors 0
SMART Information for Disk 3
Firmware: 01.01B01
SMART Attribute
Spin Up Time 6283
Start Stop Count 952
Seek Error Rate 0
Power On Hours 6217
Spin Retry Count 0
Power Cycle Count 13
Power-Off Retract Count 9
Load Cycle Count 207421
Temperature Celsius 38
UDMA CRC Error Count 1
ATA Error Count 0
Extended Attribute
Hot-add events 0
Hot-remove events 0
Lp stat events 0
Power glitches 0
Hard disk resets 0
Retries 0
Repaired sectors 0
SMART Information for Disk 4
Model: WDC WD10EACS-00D6B0
Firmware: 01.01A01
SMART Attribute
Spin Up Time 0
Start Stop Count 2
Seek Error Rate 0
Power On Hours 8
Spin Retry Count 0
Power Cycle Count 2
Power-Off Retract Count 1
Load Cycle Count 2
Temperature Celsius 34
ATA Error Count 0
Extended Attribute
Hot-add events 0
Hot-remove events 0
Lp stat events 0
Power glitches 0
Hard disk resets 0
Retries 0
Repaired sectors 0
