atz6975
Sep 20, 2008Guide
WD10EACS: Huge Load cycle count [ NOT SOLVED] in 4.2.9
Hi, could ze jedis give their opinion on the following situation: While checking my smart values after a forth drive expansion (4x1TB) I found that my three other drives that are 7 months old have...
atz6975
Sep 21, 2008Guide
FWIW...
The new drive count is not increasing at all.
So I checked with WDIDLE3 and both old and new drives use the same 8000ms timer...
I guess WD did fix something on the drive/firmware. Maybe just the way SMART reports the Load cycle count... :lol:
Please provide your own feedback.
Thank you.
Thank you.
