atz6975
Sep 20, 2008Guide
WD10EACS: Huge Load cycle count [ NOT SOLVED] in 4.2.9
Hi, could ze jedis give their opinion on the following situation: While checking my smart values after a forth drive expansion (4x1TB) I found that my three other drives that are 7 months old have...
sander11
Oct 06, 2008Aspirant
Sorry I wasn't clear. Those numbers are from another server I have set up. They're not from the Readynas.
When I fire up my WD Mybook World Edition again, I'll check the numbers on that, as it has seen more use and has WC10EACS drives in it.
I've invested in 6 of these drives with the goal of swapping out the 4 Seagate 500GB in NV+ with 4 of them and using the others as backup in other units.
I'm a little disturbed by this thread as well, but given I have these drives approaching 1500 hours of use and >50 reloads it has to be a firmware or readynas (or both) issue, not just the drives.
