atz6975
Sep 20, 2008Guide
WD10EACS: Huge Load cycle count [ NOT SOLVED] in 4.2.9
Hi, could ze jedis give their opinion on the following situation: While checking my smart values after a forth drive expansion (4x1TB) I found that my three other drives that are 7 months old have...
rstone
Nov 09, 2008Aspirant
snipes wrote: I tried using the max timer value of 25.5 seconds with wdidle3
For those of you who don't have the software mentioned by snipes and others...I found a site that has the dos utility
ftp://76.17.197.241/public/software/dos/utilities/
Good Luck!
