atz6975
Sep 20, 2008Guide
WD10EACS: Huge Load cycle count [ NOT SOLVED] in 4.2.9
Hi, could ze jedis give their opinion on the following situation: While checking my smart values after a forth drive expansion (4x1TB) I found that my three other drives that are 7 months old have...
Bigbearf
Jan 27, 2010Aspirant
@DrieStone
I am a Mac guy also but it is so much easier to use an old Windoze machine and IDE to SATA adapter to perform the Dos fix. Kind of like using a flat head screwdriver on a phillips head screw. :D
Hope this helps.
bigbearf
Hope this helps.
bigbearf
