AK471
Feb 13, 2012Aspirant
WD10EARS 1TB Caviar Green TLER not supported
I have been reading around the forum as well as the qnap forum and various online blogs and have read there may be problems when using Caviar Green drives in the ReadyNAS. I have just ran WDidle3 a...
AK471
00MVWB0
I just put the two into a brand new Pro 2 and it came up in RAIDar as corrupt root. I seem to remember having the same problem with a new Duo last month using these same HDDs (without altering the idle as I was not aware of the problem then). After a lot of restarts, resets etc. I finally got the Duo to work with these HDDs and since the duo has worked correctly. I will however check out the logs to see if it is encountering a lot of error counts.
