sandheep
Aug 16, 2012Aspirant
WD2002FAEX overheating in ReadyNAS Duo
Hi--
After having frequent RMAs on Seagate drives, I swapped one of the drives of my ReadyNAS Duo (v1) to a Western Digital WD2002FAEX. It's on the HCL, but after the upgrade, I get the following alert emailed to me after the Duo has been on for several hours:
Unexpected enclosure status detected [SURE-CON-NAS]: Disk on channel 1 reports a temperature of 55C / 131F. : Please shutdown the system immediately for service.
The Duo is sitting on an open shelf in an air-conditioned room. If I keep a fan pointed at the NAS, I don't have the issue, but after a few hours of use without the fan, I start getting this alert. The other drive in my Duo (Seagate ST3750330AS) does not suffer from this issue. Before the upgrade (i.e. with 2 of the Seagates), the NAS was operating in the same location/environment without any temperature issue for over 3 years.
I'd consider downgrading to a 5400 RPM drive, but disk access speed is critical for this unit.
Anyone else seeing overheating of the WD2002FAEX? Think WD will RMA it?
Thanks!
Sandheep
Thanks!
Sandheep
