stivo
Feb 01, 2011Follower
WD20EARS-00MVWB0 - works with NV+ or not?
Could it be clarified if WD20EARS-00MVWB0 Western Digital hard drive is officially compatible with NV+? This is the latest model which retailers stock at the moment. I doubt the approved one can ac...
zest
Feb 07, 2011Aspirant
copy of my partition.log below
Disk /dev/hde doesn't contain a valid partition table
Disk /dev/hdc: 400.0 GB, 400077971456 bytes
255 heads, 63 sectors/track, 48640 cylinders, total 781402288 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/hdc1 32 4096031 2048000 83 Linux
Partition 1 does not end on cylinder boundary.
/dev/hdc2 4096032 4608031 256000 82 Linux swap / Solaris
Partition 2 does not end on cylinder boundary.
/dev/hdc3 4608032 781385935 388388952 5 Extended
/dev/hdc5 4608040 781385935 388388948 8e Linux LVM
Disk /dev/hde: 2000.3 GB, 2000388448256 bytes
255 heads, 63 sectors/track, 243200 cylinders, total 3907008688 sectors
many thanks for decifering ... looks like it's still 512? so would I move it to 4k?
zest
zest
- Sep 05, 2011Retired_Member
