stivo
Feb 01, 2011Follower
WD20EARS-00MVWB0 - works with NV+ or not?
Could it be clarified if WD20EARS-00MVWB0 Western Digital hard drive is officially compatible with NV+? This is the latest model which retailers stock at the moment. I doubt the approved one can ac...
zest
Feb 07, 2011Aspirant
so we all good. can I please ask you if the following approach is ok to insert more drives, having the 400GB and 2TB already in there -
1. insert another 2TB and sync
2. replace the 400GB with 2TB, (power down, remove 400GB, insert 2TB, power up, hope for the resync on the new 2TB)
3. inser the fourth 2TB to complete the set and resync
would you recommend any other action?
appreciate your expert addvice
... I might get to like my NV+
zest
zest
- Sep 05, 2011Retired_Member
