stivo
Feb 01, 2011Follower
WD20EARS-00MVWB0 - works with NV+ or not?
Could it be clarified if WD20EARS-00MVWB0 Western Digital hard drive is officially compatible with NV+? This is the latest model which retailers stock at the moment. I doubt the approved one can ac...
mdgm-ntgr
Feb 08, 2011NETGEAR Employee Retired
You're supposed to factory default after upgrading to 4.1.7 or you may have poor write performance using the WD20EARS. 4k sector alignment requires a factory default after updating to 4.1.7.
There's also the adding support for drives that don't support TLER in 4.1.7.
As for expanding your volume have you tried a reboot?
- Sep 05, 2011Retired_Member
