stivo
Feb 01, 2011Follower
WD20EARS-00MVWB0 - works with NV+ or not?
Could it be clarified if WD20EARS-00MVWB0 Western Digital hard drive is officially compatible with NV+? This is the latest model which retailers stock at the moment. I doubt the approved one can ac...
gblades
Feb 09, 2011Aspirant
I only had 2 drives when it worked in 4.1.6.
The quickest way I found to upgrade to 4.1.7 with these drives is as follows and this is what I did after seeing that it was working in 4.1.6. I did this because of the fact it should have a factory reset after the 4.1.7 update
1) Put in 1 drive only and perform a factory reset.
2) As there is 1 drive after it boots there is no rebuild going on in the background so you can go straight ahead and install the update.
3) Let it reboot into 4.1.7 to make sure it has loaded ok.
4) Shutdown and fit the additional drives.
5) Perform a factory reset.
- Sep 05, 2011Retired_Member
