stivo
Feb 01, 2011Follower
WD20EARS-00MVWB0 - works with NV+ or not?
Could it be clarified if WD20EARS-00MVWB0 Western Digital hard drive is officially compatible with NV+? This is the latest model which retailers stock at the moment. I doubt the approved one can ac...
zest
Feb 14, 2011Aspirant
I need to report that after reboot my X-RAID picked up and expanded the second and third disk
so my current config is:
bay1: WD20EARS-00MVWB0
bay2: WD20EARS 00S8B1
bay3: WD20EARS-00MVWB0
bay4: WD20EARS-00MVWB0
634 GB (17%) of 3692 GB used
Ch 1 : WDC WD20EARS-00MVWB0 [1862 GB] 1859 GB allocated
Ch 2 : WDC WD20EARS-00S8B1 [1862 GB] 1859 GB allocated
Ch 3 : WDC WD20EARS-00MVWB0 [1862 GB] 1859 GB allocated
My latest problem is the error I'm getting when adding the fourth disk:
The disk attached to channel 4 could not be initialized. The most common reasons are RAID resync in progress, faulty drives, and disks that are too small to be added to the array.
[Mon Feb 14 19:46:59 EST 2011]
I have tried reboot a few times, I have also tried to init/format disk under XP - no problems. Still will not work under NV+ with the error as above.
Also I am not sure if I need to do anything about LCC
DISK1
Raw Read Error Rate 0
Spin Up Time 1000
Start Stop Count 16
Reallocated Sector Count 0
Seek Error Rate 0
Power On Hours 109
Spin Retry Count 0
Calibration Retry Count 0
Power Cycle Count 14
Power-Off Retract Count 13
Load Cycle Count 3051
Temperature Celsius 31
Reallocated Event Count 0
Current Pending Sector 0
Offline Uncorrectable 0
UDMA CRC Error Count 0
Multi Zone Error Rate 0
ATA Error Count 0
DISK2
Spin Up Time 9308
Start Stop Count 43
Seek Error Rate 0
Power On Hours 126
Spin Retry Count 0
Power Cycle Count 42
Power-Off Retract Count 41
Load Cycle Count 3667
Temperature Celsius 35
ATA Error Count 114
DISK1
Spin Up Time 966
Start Stop Count 15
Seek Error Rate 0
Power On Hours 94
Spin Retry Count 0
Power Cycle Count 13
Power-Off Retract Count 12
Load Cycle Count 2628
Temperature Celsius 33
ATA Error Count 0
Please advise ...
zest
DISK1
Spin Up Time 1000
Start Stop Count 16
Seek Error Rate 0
Power On Hours 109
Spin Retry Count 0
ATA Error Count 0
DISK2
Spin Up Time 9308
Start Stop Count 43
Seek Error Rate 0
Power On Hours 126
Spin Retry Count 0
ATA Error Count 114
DISK1
Spin Up Time 966
Start Stop Count 15
Seek Error Rate 0
Power On Hours 94
Spin Retry Count 0
ATA Error Count 0
Please advise ...
zest
- Sep 05, 2011Retired_Member
