cra1g321
Oct 11, 2011Follower
WD20EARS-00MVWB0 WD Caviar Green - 2TB
I'm recently wanting to setup a NAS to use as a backup and media streaming solution, the Netgear ReadyNAS nv+ seems like the right solution for me. Since there's 4-bays i want to put four 2TB drive...
Jemini
Oct 15, 2011Aspirant
Hi all,
I have two WD20EARS models for my NV+, one is 00MVWB0 and another is 22MVWB0. Either of them works with RAIDiator 4.1.8 [1.00a043] just fine.
readysecure1985 wrote: Hello,
The WD20EARS-00MVWB0 are NOT compatible with the ReadyNAS NV+. There is one model of the WD20EARS that is supported, Model # WD20EARS-00S8B1, with only Firmware 80.00A80.
- http://www.readynas.com/?page_id=82
Support Resources -
Forums:
Prosafe: http://forum1.netgear.com
ReadyNAS: http://www.readynas.com/forum
Prosecure: http://prosecure.netgear.com/community/forum.php
Contact support or register a device
1-888-NETGEAR (638 - 4327) Option 4 for technical support
http://my.netgear.com
Knowledge base
http://support.netgear.com
- Sep 05, 2011Retired_Member
