marksb
Dec 11, 2011Aspirant
WD20EARS-00MVWB0 Westerd Digital Cavier Green 2TB
Hi, I just got a Duo V2 and a Western Digital drive. I didn't realize there were two different versions (wished I came here first). The drive worked fine so I ordered another one, not sure what ver...
PapaBear1
Dec 11, 2011Apprentice
The drive is certainly on the Hardware Compatibility List (HCL) so it should be working ok. You might want to contact Tech Support and open a ticket. If you have owned the NAS for less than 90 days you are still in the free telephone Tech Support period. After that you will have free online support as long as the unit is under warranty.
